I have been using the trial version of Aspire. You have done an excellent job on the program!!
It amazes me that you get so much for the price!
I have one question on the brushes. The other programs I use have a "flat" brush. I dont'
seem to see anything like this in Aspire. Is there a "flat" brush? Basically if you have an
area built up that is "lumpy" the flat brush will level it out. It kinda of averages some how.
Once agian you did a great job on Aspire!
Awesome Program... and brush question.
- Turtle49
Re: Awesome Program... and brush question.
You are probably looking for the "smooth tool". Within it you can run in normal, lower or raise mode. Raise and lower are pretty self explanatory and normal kind of averages things out. Also the deposit and remove tool can add or remove material quickly.
Hope this helps,
Tim
Hope this helps,
Tim
Tim Hornshaw
www.HornshawWoodWorks.com
