Down loaded the trial of aspire and opened up the 3d file saved the toolpaths and ran them on my machine using the same size cutters as said in the toolpaths. and ended up with this result.
saved toolpaths as a .tap (g code mm) as this is what my machine wants.
What am i doing wrong
Richard
What am i doing rong with the trial
- joecnc2006
Re: What am i doing rong with the trial
what was your step over set at? 10%
Joe
http://www.joescnc.com
Joe
yes
could not save toolpath if i changed the original settings
Richard
Richard
- Model of CNC Machine: CAMaster 508 ATC
what controller do you have and whattype of machine, motors, and is it a 1/2 stepper?
jim
jim
am using a excitec 0609
it has a dsp controler
have not changed the steppers dont think they are 1/2 have not had a problem before when i made lithos or did photo v carving
thanks
Richard
thanks
Richard
no an 0609 is a microstepper machine
jim
jim
