Can I Create a Component, and Not have it in the working model? The shape of that component is in the 3d pane.
How do I know I've copied the component into the working model?
Can the component be copied into the component more than once?
Sorry Guys, just trying to get a handle on what I'm actually seeing.
Componet -- Model
- RoutnAbout
Re: Componet -- Model
Don, You can create a component and not have it in the working model.RoutnAbout wrote:Can I Create a Component, and Not have it in the working model? The shape of that component is in the 3d pane.
Once a component is placed into the working model it will appear yellow on the 2d pane. And you can place a component into the working model as many times has you wish.
- JamesB
- Vectric Alumni
If your not sure what is in your working model and what is a component the quickest way to check (I think) is to go to the component manager and switch off all the components (right mouse click in the list and choose the Hide all Component option) - now whatever is left in the 3D View is what is in your Working Model (this is very quick to check).
As Chuck said, you can definitely copy a component multiple times into your Working Model so you should take care with that. Cheers,
James
James
- RoutnAbout
Thanks James, that really helps.
And after I read your post, I remembered hearing watching that on the video.
I guess watching the videos just a couple times isn't enough.
Thanks James
Thanks James
- RoutnAbout
Whats the purpose of the yellow tinged object once its turned into the component?CRFultz wrote:Don, You can create a component and not have it in the working model.
I can't seem to find a way to hide it or move it. Do I need it?
Since I have the grayscaled component, I'm assuming I can delete the vectors creating the component as I can trace the grayscale component.
- JamesB
- Vectric Alumni
The yellow tinged grayscale is not an object (which is why you cannot select or move it). It is just a 2D preview of what is currently in the working model (same as the non-yellow tinged grayscales are 2D view of the components). If there is nothing in the working model there is no yellow-tinged grayscale. If there is any shape in the working model then you will see it. Only purpose of it is as a help when you are looking at the 2D.
James
James
- RoutnAbout
Thanks Chuck and James, I do appreciate your help and Tips..
