Convert a Crv-file to STL?
jaru-eri
Model of CNC Machine: Taig and router, Gecko G540, Mach3
Post by jaru-eri »
I have a Crv-file created with moulding toolpath, but these toolpaths doesn´t allow raster x but cuts instead around A-axis and when I try to run this offline, the prosess run very slow.
My problem is that I have only Vcarve pro and can´t export this file as an STL for importing it again for a different toolpath calculation.
Are there anybody here who can help me with converting this file and post it here so I can try another option in order to get a faster prosess?
sphere 92mm.crv
(102.5 KiB) Downloaded 126 times
jaru-eri
Re: Convert a Crv-file to STL?
Post by jaru-eri »
I forgot to upload an image. Here it is:
garylmast
Post by garylmast »
Try this one.
Gary
sphere 92mm.zip
(58.23 KiB) Downloaded 167 times
jaru-eri
Post by jaru-eri »
Thank you Gary. This I really appreciated.
Post by adze_cnc »
If you just want a 92mm diameter sphere--without the attached "flanges"--try this model. You could then add your own 3D tabs to it. Just import the .3DM file as you would a .STL model.
Steven
92mm-sphere.zip
92mm diameter sphere (Rhinoceros v5)
(158.19 KiB) Downloaded 72 times
