Version 10 Hints
Version 10 Hints
Postby ohiolyons » Tue Sep 03, 2019 4:01 pm
on Facebook Vectric Ltd group has what's in threads as of yesterday.
on Twitter The Vectric Team
Yesterday text welding
today level clipping
Hopefully they will keep it up each day!!!!!!
CNC in Kettering, Ohio
ohiolyons
Model of CNC Machine: Laguna IQ HHC, 3HP
Re: Version 10 Hints
Postby wb9tpg » Wed Sep 04, 2019 2:58 pm
Tool Database OVERHAUL - Do you use the same tool, but want different speeds & feeds for different materials? In V10 you can adjust the parameters based on your material. Then, filter the tools to see only the ones that are compatible.
I'd probably update just for this feature alone
wb9tpg
Postby Jim_in_PA » Thu Sep 05, 2019 2:12 pm
I agree totally...this is a huge upgrade. Hopefully, it can be keyed not just to "material", like wood, foam, etc., but to other factors even in the same material.
The text welding is a nice feature to speed things up, although one must still enter node-edit to insure things are smooth, depending on the particular font.
Jim_in_PA
Model of CNC Machine: Camaster Stinger II SR-44 (MacOS user)
Postby ohiolyons » Thu Sep 05, 2019 3:03 pm
New /enhanced sculpting tools look good too.
I would use all the new stuff so far!
Come on down 4 sided machining, please.
ohiolyons
Postby roy_okc » Thu Sep 05, 2019 6:39 pm
I upgraded from VCarve 6(?) to Aspire 8 shortly after 8 came out. I skipped 9 as I wasn't doing much at that time and I didn't see enough benefit in it for me personally to make that upgrade. However, will definitely be upgrading to 10 as soon as it comes out.
On the tool video, who noticed that there was also a drop down for machine as well as material? That will be great for me, I have a small machine that can only take up to 1/4" tools and a medium machine that can take up to 1/2" tools. As wb9tpg said, this upgrade alone is nearly worth the upgrade cost for me, but I'll be glad for other things. :)
roy_okc
Model of CNC Machine: DIY 80/20 ~18"x48", Mach 3
Postby wb9tpg » Thu Sep 05, 2019 6:52 pm
Oh yes please!
wb9tpg
Postby 4DThinker » Fri Sep 06, 2019 1:38 am
If you're going to ask for 4, go ahead and ask for 3 or 5 or 6 sided machining using the rotary axis.
4DThinker
Postby Jim_in_PA » Fri Sep 06, 2019 2:08 pm
Yea, the sculpting enhancements also look interesting...I have a job coming up that could benefit from that actually.
Jim_in_PA
Return to Aspire - General
Users browsing this forum: No registered users and 25 guests
