help finding a post
help finding a post
Postby ohiolyons » Wed Aug 28, 2019 2:38 pm
The other day I saw a post concerning a double sided cut of what looked to be a skate board.
I searched for skateboard, skate board, snowboard and snow board without any luck.
There question concerned cutting below the zero plane on the back side to get at the undercut area from the front side.
Apparently I didn't subscribe and now I can't find it.
Hopefully I wasn't dreaming and someone will remember the post and can direct me there.
Thanks in advance.
CNC in Kettering, Ohio
ohiolyons
Model of CNC Machine: Laguna IQ HHC, 3HP
Re: help finding a post
Postby garylmast » Wed Aug 28, 2019 2:48 pm
I'm not sure what post you're talking about, but to get an undercut, either when you import the model, select create both sides and then set the overcut distance. Or if you already have the model, make sure you have a limit plane (zero plane) on a different level and in it's component properties, set the base height at a Negative distance.
Gary
garylmast
Postby ohiolyons » Wed Aug 28, 2019 4:42 pm
Never saw the over cut option before, I'll look into it, Thanks.
ohiolyons
Postby WNC_Ed » Wed Aug 28, 2019 4:50 pm
There was a beer tap awhile back ... could have looked like a skateboard - sorta???
https://forum.vectric.com/viewtopic.php?f=2&t=31349&p=226446&hilit=undercut#p226446
That is the closest thing I recall ...
Hope it helps.
Maker of sawdust
WNC_Ed
Postby ohiolyons » Wed Aug 28, 2019 4:52 pm
Beer tap not the one, thanks.
This was just a couple days ago.
ohiolyons
Postby ohiolyons » Wed Aug 28, 2019 7:29 pm
Generated my own "skateboard" shape in SKECTUP and exported it as an STL.
I then imported it into Aspire and the OVERCUT DISTANCE allowed me to do what I was trying to figure out.
Interesting enough the feature is not addressed in the manual or if it is I can't find it.
guess I'll send vectric a heads up.
Thanks all.
ohiolyons
Postby SteveNelson46 » Wed Aug 28, 2019 8:06 pm
Check out the two sided video of a Marlin in the Vectric tutorials.
https://support.vectric.com/tutorials/V ... ideo_id=51
SteveNelson46
Postby RebeccaJ » Tue Sep 03, 2019 8:22 am
Hey Ohiolyons,
This isn't a skate board but Sean made a tutorial a few years back covering how to model a guitar neck, which covers the clever modeling of the head stock (creating a part that is all on one side but needs cutting on both sides) If this is something you are interested in the video can be found here:
https://www.vectric.com/vectric-communi ... =1&items=0
I hope this helps,
Beki
Beki Jeremy
Senior Application Engineer - Vectric Ltd.
RebeccaJ
Vectric Staff
Model of CNC Machine: Various
Return to Aspire - General
Users browsing this forum: Jim_in_PA and 20 guests
