Fillets on stub tenon
I want to place 3/8" fillets around this stub tenon where it meets the leg. I can't figure or remember how to do it.
- Test.crv3d
- (1.89 MiB) Downloaded 92 times
- rscrawford
Re: Fillets on stub tenon
Very difficult in Aspire, because of the compound curves required. That would be a better job to design in a NURBS based CAD program, like Rhino, and then import into Aspire for toolpathing.
Russell Crawford
This is one way of accomplishing it but probably not the only way.
To make this I created a vector around the joint area and then digitally machined that area with a .75 inch ball nose and a fine step over (1%). I digitally machined the rest with a .250 ball nose and a fairly fine step over. I then created an outline with .375 inch radius fillets and cut out the model from the background. After double clicking on the waste material I was left with this preview.
Under the modelling tab there is an option to create a component from the toolpath preview. Euan
- Model of CNC Machine: Thermwood CS-45 5 x 10
Cut it with a 3/4 Ball nose and the tool will automaticy, create, the fillet, around the base of the extrusion
Will Williamson willmade.com
Capac, Michigan
Capac, Michigan
Thanks for the responses. I used a 2 rail to make the tenon, including the fillet on top. It worked fine but the I didn’ like how it looked ad scrapped the fillets. I forgot the component from preview tool. Thanks. I will try to remember it.
