Fillets on stub tenon
Postby Wayne Locke » Tue Aug 27, 2019 10:46 pm
I want to place 3/8" fillets around this stub tenon where it meets the leg. I can't figure or remember how to do it.
Test.crv3d
(1.89 MiB) Downloaded 9 times
Wayne Locke
Re: Fillets on stub tenon
Postby rscrawford » Wed Aug 28, 2019 3:28 am
Very difficult in Aspire, because of the compound curves required. That would be a better job to design in a NURBS based CAD program, like Rhino, and then import into Aspire for toolpathing.
Russell Crawford
rscrawford
Postby eph210 » Wed Aug 28, 2019 6:45 am
This is one way of accomplishing it but probably not the only way.
To make this I created a vector around the joint area and then digitally machined that area with a .75 inch ball nose and a fine step over (1%). I digitally machined the rest with a .250 ball nose and a fairly fine step over. I then created an outline with .375 inch radius fillets and cut out the model from the background. After double clicking on the waste material I was left with this preview.
Under the modelling tab there is an option to create a component from the toolpath preview.
Euan
eph210
Model of CNC Machine: Stinger 1 and Mabel, both with 4 axis
Postby Will Williamson » Wed Aug 28, 2019 6:00 pm
Cut it with a 3/4 Ball nose and the tool will automaticy, create, the fillet, around the base of the extrusion
Will Williamson willcnc.com willmade.com
Williamson Lumber & Millwork Inc.
Capac, Michigan
Will Williamson
Model of CNC Machine: Thermwood CS-45 5 x 10
Postby Wayne Locke » Fri Aug 30, 2019 6:10 am
Thanks for the responses. I used a 2 rail to make the tenon, including the fillet on top. It worked fine but the I didn’ like how it looked ad scrapped the fillets. I forgot the component from preview tool. Thanks. I will try to remember it.
Wayne Locke
Return to Aspire - General
Users browsing this forum: ohiolyons and 21 guests
