Moulding tool path help
Postby mccandj » Sun Aug 25, 2019 7:24 pm
Any help on this? I've moved the drive rail, resized it, made the working area bigger and about every other thing I can think of. This is a simple crown moulding profile I need to make a piece of.
mccandj
Model of CNC Machine: Camaster Stinger I 24
Re: Moulding tool path help
Postby gkas » Sun Aug 25, 2019 7:38 pm
It will be much easier if you post your project file (crv3d).
gkas
Postby mccandj » Sun Aug 25, 2019 7:46 pm
How do i find the file?
mccandj
Postby Adrian » Sun Aug 25, 2019 7:47 pm
mccandj wrote:How do i find the file?
Its wherever you save it. The CRV3D file is the Aspire project file that you save and load.
Postby 4DThinker » Sun Aug 25, 2019 8:36 pm
You need to be sure the profile vector is selected last when using the moulding toolpath.
4DThinker
Postby mccandj » Sun Aug 25, 2019 10:26 pm
Profile is selected last. I also completely re did the design and file and still get the same message. I was hoping it was something simple that someone has ran into and dealt with. My design computer is not online so I may have trouble uploading the file but I'll give it a try.
mccandj
Postby highpockets » Sun Aug 25, 2019 10:42 pm
Looking at the picture, you're using a 1/4" BN. Not knowing the scale of your drawing, but it looks like the BN won't fit in the V area of your profile pattern.
Try a smaller bit or use a 1/4" BN for clearance toolpath then a 1/8" or so for the finishing. You may still have problems because of the pointy bottom of the V.
Postby dealguy11 » Sun Aug 25, 2019 11:18 pm
I don't think it's the tool. Aspire and V-Carve Pro will happily use a larger tool that won't fit in portions of the profile. This error always has to do with the vectors and their relationships. There is something weird in the picture you included...it shows no gap above or below, and zero depth of cut, nor are there any of the lines it usually shows to indicate how the profile has been applied to the rail. Hope you can find a way to show us the actual file, as something has been selected wrong.
Steve Godding
dealguy11
Postby mccandj » Mon Aug 26, 2019 12:49 am
Update. I went back out and re did the program again. Re drew the profile. This time it seemed like is was going to show the tool path and then the program just shut down. Did it to me twice. Before it did that, it made what looked like a v carve tool path on the line and the profile. It was really weird. So, I'm thinking there might be some kind of glitch in that portion of my software?? I've never had any other problems with other tool paths. Thanks for trying to help.
I have a copy of V carve as well and I'll give it a try on that tomorrow.
If I can find a way to upload the file, I will. I"m currently on a Mac online and my design computer is a PC in the shop not online....plus I'm not the best with Tech. So, might not happen.
mccandj
Postby mohamed » Mon Aug 26, 2019 11:32 am
mccandj wrote:Update. I went back out and re did the program again. Re drew the profile. This time it seemed like is was going to show the tool path and then the program just shut down. Did it to me twice. Before it did that, it made what looked like a v carve tool path on the line and the profile. It was really weird. So, I'm thinking there might be some kind of glitch in that portion of my software?? I've never had any other problems with other tool paths. Thanks for trying to help.
Did you get any crash reports or messages?
Could you please email the file to support@vectric.com along with any log files and dump files from that day (found through File Menu -> Open Application Data Folder) and any steps to reproduce the problem.
Mohamed
mohamed
Vectric Staff
Postby mccandj » Mon Aug 26, 2019 1:57 pm
Did not get any kind of report of error message. It just shut down. I'll try my best to forward the file. Thanks for your help.
mccandj
Return to Aspire - General
Users browsing this forum: AdsBot [Google] and 5 guests
