Font Issue
Font Issue
Postby Tscholl » Thu Aug 22, 2019 10:50 pm
I am trying to cut a small sign with Alcubierre font. It an open font. When I cut the sign I get ‘bumps’ or overlaps. Notice on the letters g, u and r. The bumps don’t show when I run the preview. I am running this on a Biesse Skill. The VPOINT bit is a 60 degree cutter. Aspire version 9.517. I've attached the crv3d and a pdf of the actual cutout.
Is there a way I can run this file without the bumps?
font issue.pdf
(1.11 MiB) Downloaded 37 times
MID OFFICE.crv3d
(710 KiB) Downloaded 17 times
Tscholl
Model of CNC Machine: Biesse Skill
Re: Font Issue
Postby highpockets » Fri Aug 23, 2019 12:14 am
Might want to check that the 60° bit is actually 60°
viewtopic.php?t=2164
Re: Font Issue
Postby Rcnewcomb » Fri Aug 23, 2019 1:02 am
In the file you attached you specified a 90 degree V bit.
Re: Font Issue
Postby Tscholl » Fri Aug 23, 2019 3:22 pm
That was it - I had the wrong information in the tool data - thanks
Tscholl
Return to Aspire - General
Users browsing this forum: No registered users and 27 guests
