2 objects to 1?
- Model of CNC Machine: AXYZ Pacer 5010
2 objects to 1?
I need help. New user with Aspire. If I import a file that has two objects, how can I delete one of them? In Vcarve Pro, you could simply select one and delete it. I cannot figure out how to do this. Thanks in advance.
Re: 2 objects to 1?
Draw a line between the object where you want to split it. Hit the Scissor Icon which will split it. You will then have two components, that if you don't want one, you can delete it.
Gary
Gary
Re: 2 objects to 1?
Thank you for the response. I drew a line. Then when I went to split it I received the following message.
- Leo
Re: 2 objects to 1?
They might be grouped -- try grouping then delete same as vcarve
- SteveNelson46
Re: 2 objects to 1?
Be sure to select the component then hold down the shift key and select the line. Then click on the "Split Selected Component Using a Vector" button
- mtylerfl
Re: 2 objects to 1?
He’s already got it sorted. I helped him on FaceBook
