Windsor seat contour Question
Postby gene8522 » Tue Aug 06, 2019 12:19 am
I need help using Aspire 9.5 to make a contour of this Windsor seat. I'm having trouble deciding what to use to make this model. Should I try using 2 rail sweep or would 'Create Shape' work best. I've looked at the tutorials videos without many answers.
Any help from you Aspire, 9.5 wizards, would sure be appreciated. :wink: :wink:
Seat Contour.eps
(56.85 KiB) Downloaded 20 times
Seat Contour 5.ai
(50.69 KiB) Downloaded 19 times
gene8522
Model of CNC Machine: Shop built
Re: Windsor seat contour Question
Postby Adrian » Tue Aug 06, 2019 4:32 pm
Do you have the option of a 3D format rather than 2D format file for this?
Postby gene8522 » Tue Aug 06, 2019 5:11 pm
Adrian wrote:Do you have the option of a 3D format rather than 2D format file for this?
Sorry, Adrian I only have a plan drawing that shows the contour lines and the depth for the seat. The Windsor chairs are meant to be hand-carved, but since I have a CNC I would like to try and use it to make the carved seats. One guy I found on another web site says that he uses SketchUp and 'sandbox' to draw the contours. I have SketchUp but I'm not sure how to use the 'sandbox', and I'm a little impatient with the learning curve to learn how to use 'sandbox'. :roll:
gene8522
Postby SteveNelson46 » Tue Aug 06, 2019 6:20 pm
There are a lot of posts on this subject. Just search for "chair seat".
SteveNelson46
Postby adze_cnc » Sat Sep 14, 2019 12:37 am
The contours in the EPS and AI files do not match those in the screen-shot. The contours in the screen appear to have Z-heights associated with them. Is it possible to get the file that is represented in the screenshot?
Steven
adze_cnc
Return to Aspire - General
Users browsing this forum: Fleming, roy_okc and 5 guests
