Convert a Crv-file to STL?
Postby jaru-eri » Fri Aug 02, 2019 3:35 am
I have a Crv-file created with moulding toolpath, but these toolpaths doesn´t allow raster x but cuts instead around A-axis and when I try to run this offline, the prosess run very slow.
My problem is that I have only Vcarve pro and can´t export this file as an STL for importing it again for a different toolpath calculation.
Are there anybody here who can help me with converting this file and post it here so I can try another option in order to get a faster prosess?
sphere 92mm.crv
(102.5 KiB) Downloaded 15 times
jaru-eri
Model of CNC Machine: Taig and router, Gecko G540, Mach3
Re: Convert a Crv-file to STL?
Postby jaru-eri » Fri Aug 02, 2019 5:57 am
I forgot to upload an image. Here it is:
jaru-eri
Postby garylmast » Fri Aug 02, 2019 1:25 pm
Try this one.
Gary
sphere 92mm.zip
(58.23 KiB) Downloaded 18 times
garylmast
Postby jaru-eri » Fri Aug 02, 2019 7:27 pm
Thank you Gary. This I really appreciated.
jaru-eri
Postby adze_cnc » Wed Sep 11, 2019 4:44 pm
If you just want a 92mm diameter sphere--without the attached "flanges"--try this model. You could then add your own 3D tabs to it. Just import the .3DM file as you would a .STL model.
Steven
92mm-sphere.zip
92mm diameter sphere (Rhinoceros v5)
(158.19 KiB) Downloaded 4 times
adze_cnc
Return to Aspire - General
Users browsing this forum: No registered users and 20 guests
