Stepover lines?
Stepover lines?
Postby rtibbs2018 » Wed Jul 03, 2019 12:42 am
I know it's a lousy picture however, it's the best angle I could get to capture what I'm questioning.
On the final 3D finish pass I am getting a section several pass widths wide which are cutting slightly deeper than the rest.
They are very noticeable to the naked eye and the 'fingernail' test
Not sure what is causing this however, I'm "assuming" it's machine related.
Still learnin'
Ron
rtibbs2018
Model of CNC Machine: Shopbot desktop
Re: Stepover lines?
Postby TReischl » Wed Jul 03, 2019 12:58 am
Maybe, maybe not.
I used to get that quite a bit when I would use models that were exported from another program as bitmap files (bmp). The grayscale would look perfect coming out of Corel but when converted into a model, there they were. Never did figure out what exactly was causing it. Some of the experts here (Randy Newcomb IIRC) advised me to use a .tiff format instead. That helped quite a bit.
Re: Stepover lines?
Postby wb9tpg » Wed Jul 03, 2019 3:07 am
Still learnin'
Ron
I'd agree and look at tramming your machine
wb9tpg
Re: Stepover lines?
Postby scottp55 » Wed Jul 03, 2019 11:53 am
Any possibility you were leaning on the machine at that particular point to inspect the cut?
Somebody posted once, and turns out that what it was :)
GMH
scottp55
Re: Stepover lines?
Postby ger21 » Wed Jul 03, 2019 11:58 am
Tramming won't fix that. It's mostly likely a loose coupler or something similar, where it moved a little one way, then moved back to where it was.
ger21
Re: Stepover lines?
Postby 4DThinker » Wed Jul 03, 2019 12:55 pm
Depending on how the toolpath was set up, it could be that after clearing an area the board may have bowed up. When the bit comes back to clear an area it previously skipped for efficiency it cuts relatively deeper even though to the CNC it was cutting perfectly as programmed. I've had exactly this happen when cutting 3D surfaces that cover most of a board. Wood moves.
4D
4DThinker
Re: Stepover lines?
Postby TReischl » Wed Jul 03, 2019 1:38 pm
What all these posts indicate is that there is a lot of things that have to be right or else. . . . . grrrrr.
Re: Stepover lines?
Postby rtibbs2018 » Wed Jul 03, 2019 2:12 pm
Thanks guy's,
lots to consider.
Everything seems to be right and tight, not leaning on machine.
These are D&M files with one exception that was an imported .obj file combined with a Vectric clipart plaque. so I would hope they are not the issue.
It's not the first time it's happened.
Unfortunately, I believe it comes down to "You get what you pay for" :mrgreen:
May be time to upgrade my machine as I purchased this one to see if CNC'ing was something I'd be interested in continuing...….It is :mrgreen:
I guess I could always stick with 2D but what's to fun in that!
rtibbs2018
Return to Aspire - General
Users browsing this forum: SteveNelson46 and 9 guests
