Tool Numbering
Re: Tool Numbering
Postby Jim_in_PA » Sun Jul 07, 2019 3:58 pm
Gary, in your classes, you touch very nicely on tool database management techniques and those thoughts are actually how I eventually settled on what works best for me as I described above. But yea..."machine matters" clearly! The OP also has Camaster with an FTC like I do, but many others will have to potentially handle things differently.
Jim_in_PA
Model of CNC Machine: Camaster Stinger II SR-44 (MacOS user)
Re: Tool Numbering
Postby IslaWW » Sun Jul 07, 2019 4:43 pm
Jim...
You are right. You left out the part where I explained that I had started out with 150 tools and wanted/needed 150 numbers. It didn't all that long to find out that was not going to be a good way to go, so I teach a few different methods. Most everyone uses one that attends, possibly with a few variations, uses of those methods successfully.
Gary Campbell
CNC Technology & Training
GCnC411 (at) gmail.com
IslaWW
Re: Tool Numbering
Postby Jim_in_PA » Mon Jul 08, 2019 3:32 pm
Yea, I think it's a natural initial inclination to have a unique tool number for every stinkin' tool in the shop, but then...reality sets in. :) Ten is a nice round number and it's relatively easy to work things out to make things reasonably simple with a little thought. And most jobs only use 1-3 cutters in my experience with what I do anyway.
Jim_in_PA
Re: Tool Numbering
Postby dealguy11 » Mon Jul 08, 2019 6:14 pm
I have an 8-position tool changer and I try to manage it by putting similar tools on the same number. For example:
Tool 1 is always a cutout tool
Tool 2 is always a large pocketing tool
Tool 3 is always a 1/2" end mill - either up or down depending on need
Tool 4 is always a ballnose
Tool 5 is always a 1/8" downcutter
Tool 6 is always a 1/4" downcutter
Tools 7 and 8 are the ones I change as needed - I usually put v-cutters on 7 and whatever profile tool is needed on tool 8
There's no magic to this - it just helps me to remember what to check before the run starts and helps make sure the tools I need most are always available. And, like all rules, they can be broken for jobs that require it.
Steve Godding
dealguy11
Re: Tool Numbering
Postby Rcnewcomb » Mon Jul 08, 2019 7:19 pm
Like Steve, I have a standard pattern based on my 5-tool ATC:
Tool 1: Large End Mill
Tool 2: Small End Mill
Tool 3: V-bit, or form Tool
Tool 4: Large ballnose
Tool 5: Small ballnose
Previous
Return to Aspire - General
