Create a double sided model from a single sided model
Postby fordtman » Mon Jun 24, 2019 6:51 am
I have created a single sided model and want to create a double sided model from is i.e. a reverse mirror image of the single sided model. Can anyone enlighten me please. I have done it before but cannot remember how (I am old). :( :D :? :roll:
fordtman
Model of CNC Machine: AKG6090
Re: Create a double sided model from a single sided model
Postby garylmast » Mon Jun 24, 2019 12:54 pm
There's a couple of ways you can do it. Make sure you are in a Double-sided Job setup. Make sure the model is centered, then right click and copy to other side. Go into the Modeling tab and adjust the shape height under Component Properties. Under the component tab, ADD a Tab level and a Zero plane level. In the Zero Plane put a negative number to adjust for the amount of undercut. The Tab level you can add tabs from the clipart.
Another way is after you have doubled it and adjusted the thickness, export the model out as a stl file. Then import it again and the Component setup with the Levels will already be in place.
Gary
garylmast
Postby TReischl » Mon Jun 24, 2019 1:05 pm
Or, create the model in a two sided job setup as Gary stated.
Do a control-c to copy the model. Flip over to the reverse side, and paste the model. Then do a vertical mirror.
http://www.tedreischl.com
Low Profile CNC Router Vise
Postby fordtman » Tue Jun 25, 2019 1:32 am
Thanks guys. I tried all the suggestions and they all worked perfectly. I have recorded them in my Alzheimer's file so I won't forget again, I just have to remember where my Alzheimer's file is. Thanks again.
fordtman
Postby highpockets » Tue Jun 25, 2019 2:09 am
Return to Aspire - General
