DWG Files
DWG Files
Postby mik58gar » Sat Jun 15, 2019 10:49 pm
can these files easily be imported and converted in aspire 9.5?
mik58gar
Model of CNC Machine: Axiom AR8 Pro+
Re: DWG Files
Postby Savannahdan » Sat Jun 15, 2019 11:45 pm
I looked at the file types for Aspire and dwg is one that you can use Open an existing file to bring it directly into Aspire.
Savannahdan
Re: DWG Files
Postby mik58gar » Sat Jun 15, 2019 11:55 pm
Ah...I see that now. Thank you for your help. I'm new to Aspire and CNC'ing. I'm looking to import some plans for adirondack chairs. They're in DWG file format. I wanted to make sure I could use them prior to buying them.
mik58gar
Re: DWG Files
Postby ger21 » Sun Jun 16, 2019 12:22 am
There are different version numbers for the .dwg format. I'm not sure what the latest version is that Aspire supports.
ger21
Re: DWG Files
Postby dealguy11 » Mon Jun 17, 2019 12:06 am
After import, check the sizes of the parts imported. If the original file was saved in millimeters and you're in inches (or vice versa) then you make have to resize.
Steve Godding
dealguy11
Re: DWG Files
Postby Dale Vanderlaan » Mon Jun 17, 2019 1:41 pm
I'm using AutoCad 2018 and it imports just fine when I use the 'Import Vectors' button next to the 'save' button on the 'Drawing' menu tab. What I really like is that if I only want to bring in a certain layer or two from a more complicated AutoCad .dwg file, I just turn off the layers I don't want to import in AutoCad and re-save the .dwg. Then the 'Import Vectors' in Aspire only reads-in those layers.
Dale
Dale Vanderlaan
Model of CNC Machine: Axiom 8 Pro
Return to Aspire - General
Users browsing this forum: No registered users and 11 guests
