zero from same side assistance
Postby ohiolyons » Sat Jun 08, 2019 6:52 pm
In double sided machining I tried doing a zero from same side for the first time.
Zeroed Z from top of the material on side one.
Everything went as expected.
Flipped the board over and zeroed Z from the spoil board.
Luckily I had a long depth of cut bit it cut all the way through and cut the image into the spoil board.
Completely destroying the first side, obliviously I do not understand the concept! Any assistance will be greatly appreciated.
I did search the forum for similar issues and found one, but it used Mach 3 terminology and made it difficult to relate to my issue.
JOHN
CNC in Kettering, Ohio
ohiolyons
Model of CNC Machine: Laguna IQ HHC, 3HP
Re: zero from same side assistance
Postby TReischl » Sun Jun 09, 2019 1:04 pm
I haven't used that feature but. . .
When I do anything "new" that causes me to wonder if I am doing it correctly I take a quick look at the GCode before running.
In your case since you zeroed from the spoil board there should not be any Z- moves unless you want to cut into the spoil board. A simple search in something like NotePad for "Z-" would tell you right away.
I guess I finally made enough mistakes with that sort of thing to decide it is better to take a minute or so to look things over first. Quite often the stuff I do might have several hours of cutting before I make a big honking mistake like that and ruin everything and that frustrates the heck out of me.
Just ran a test of that Zero off Same Side option. Worked as advertised. In the first side program all cutting moves were Z-, in the second side cutting moves all were Z+.
Maybe you loaded the wrong file?
I run Mach3 and this has nothing to do with Mach3 terminology or Mach3 for that matter.
http://www.tedreischl.com
Low Profile CNC Router Vise
Postby mtylerfl » Sun Jun 09, 2019 1:16 pm
Hi John,
We don’t have enough info to be able to help you very well. If possible, make your file available for download so someone can look at how you’ve setup the double-sided carve.
I suspect that there may be an error in how your Limit Planes are placed in your project. It may be as simple as adjusting their position. There is an excellent video in the Support section of the Vectric website of a two-sided Dolphin Tutorial that might help explain the overcut procedure and limit planes, etc. Watch that video when you have a chance.
Postby ohiolyons » Sun Jun 09, 2019 1:44 pm
Horrible did I say HORRIBLE case of operator error!!!!!!!!!
As I said, side 1 went as expected.
After a good nights rest the answer pops into my head.
I should always wait for a good night's sleep before asking questions on the forum.
NOTE to self!!!!!!
As I said I flipped the work piece over, zeroed on off the spoil board and total fail.
It is important to note that you run the roughing toolpath for side 2 NOT side 1.
I went out to my CNC and checked the recently run menu and low and behold the roughing toolpath for side 2 was not run!!!!!!!!!! :cry: :cry: :cry:
Sorry for the false alarm, but I'm sure I was not the first nor the last to do this.
The sad part is I name my toolpaths with F1xxx for the first toolpath on the front, F2xxx for the second, etc.
The xxx part is the bit number.
B1xxx for the first toolpath on the back, just so things like this don't occur!!!
Again thanks to all hope this prevents someone else's operator error.
It will bring a chuckle to the CNC user groups I belong to.
ohiolyons
Postby scottp55 » Sun Jun 09, 2019 2:06 pm
:wink: :wink: :wink: :wink: :wink:
Sorry John...But I would NEVER make that misteak! :D
Hmmm, BUT I DO label my toolpaths FRONT and BACK...hmm wonder why I do THAT? :wink:
MUCH more common mistake for me is to Z-Zero off the WRONG surface! :oops:
BET you a dollar you won't do THAT again!! :D
Don't feel like the Lone Ranger:)
scottp55
Postby TReischl » Sun Jun 09, 2019 3:53 pm
HAH! I can out blunder anyone!
My big one is getting in a hurry and not zeroing at all when changing jobs.
So there I was, cutting 3/4 material. Tossed in some 1 1/2 thick stuff, geeee, I wonder why my collet is buried in the wood and smoking now?
How did I fix that issue? Modified the post so that now the machine always moves to 3 inches above Z0, moves to X0,Y0 and then hits an optional stop. That way I get to THINK before continuing. Has saved my bacon multiple times.
Postby scottp55 » Sun Jun 09, 2019 4:13 pm
My personal favorite is misplacing the Z decimal point!!! :D
It LOOKS right, and then after the Panic.....I move the speck of dirt off my screen :D
Pesky decimal points should automatically get BIGGER as you age!!
scottp55
Postby ohiolyons » Sun Jun 09, 2019 10:06 pm
Cut it with the proper toolpaths to the appropriate side, zeroed correctly and it is great!
Thread now closed, Thanks to all.
ohiolyons
Postby highpockets » Sun Jun 09, 2019 10:10 pm
When cutting double sided projects I create a Front directory and a Back directory to keep the gcode files separated.
Postby Leo » Sun Jun 09, 2019 10:25 pm
SOMETIMES - but not always I do this and it helps.
When I feel tired I know I should STOP, shut everything down and go in the house and chill out.
SOMETIMES - when I do that things work out well.
Ahhhh - but it's the rest of the story as Paul Harvey put it that bites me.
Yep, I know what its like to try and send a tool in RAPID down into the floor.
Yep I know full well that yelling NO NO STOP, errr or some other words, - does NOT stop the machine.
www.leosworkshop.com
Leo
Return to Aspire - General
Users browsing this forum: Google [Bot] and 30 guests
