I'm trying to incorporate a 3d model with a moulding toolpath.
Page 216 of the manual implies it is possible. I could not find a tutorial that addresses this.
The paragraph on page 216 happens to be a repeat of page 209 which is the section immediately before the Moulding Toolpath section.
So my question is this possible or do we have a bad copy paste error in the manual?
If it is possible could you steer me to a tutorial?
Thanks in advance.
Moulding toolpath with 3 d model help
- ohiolyons
John Lyons
CNC in Kettering, Ohio
- jimwill2
- Model of CNC Machine: CaMaster Stinger w/recoil, FTC
Re: Moulding toolpath with 3 d model help
I believe the moulding tool creates a 3-D 'shape' that is not the same as a 3-D 'model.' You cannot 'project a toolpath on a 3-D model' with a moulding toolpath. I don't know about the manual or the tutorials. I could be wrong.
Jim Williams
- mtylerfl
You can run the toolpath preview of your moulding toolpath, then use the "Create Component from Toolpath preview" feature. I don't know exactly what you are trying to accomplish, but you may want to make a profile cutout as part of the preview, delete material, THEN use the create component from preview feature (might need to add a Base Height as well...like I say, I have no idea what you are trying to make, so use your noodle as to what else may be required!).
I believe it is a documentation error. There would be some significant problems with trying to get the "machine flat regions" of the moulding toolpath to still work over a 3D shape.
- highpockets
Do you have a picture of what you're trying to do?
- ohiolyons
Thanks for confirming my suspicions.
I belong to 2 CNC user's groups (Dayton, Ohio Woodcraft and Cincinnati, Ohio Rockler) with the only common denominator being Vectric software.
I was preparing a demo generic moulding toolpath for our VCarvePro people.
As I was doing it I thought "how/can I add a 3d model to this"?
Looked in the manual and it implies that it can be done.
After numerous attempts and then printing the manual pages out I saw the section under moulding toolpath appeared to be a repeat of the previous section.
Thanks for your insights
John Lyons
