Cut Sequence
Cut Sequence
I have a series of holes that need to be cut and I would like for them to be cut in a specific order. I cannot find the setting that will let you set the cut sequence. How would I go about doing this? I appreciate the help!
Re: Cut Sequence
Depends what toolpath you're using. If you're using the drill or pocket toolpath then you need to select the vectors in the order that you want them cut and check the Use Vector Selection order box on the toolpath.
If it's a profile toolpath then make sure the Show advanced toolpath options at the top of the profile toolpath form is checked and then use one of the options on the Order tab further down the form.
