the release notes associated with this version 9.517 stop at 9.516.
Does anyone know what was fixed and any additions if applicable?
The availability of this version was found by manually checking for an update, the automatic notification did not occur.
release notes 9.517
- ohiolyons
release notes 9.517
John Lyons
CNC in Kettering, Ohio
Re: release notes 9.517
It's showing in the release notes for me. Maybe you caught it as it was being rolled out?
- Fix tolerance issue in Moulding Toolpath when using second tool.
Fix failure to remove centre when pocketing some circles in some cases.
Fix STL exporting issue when the model was touching the edge of the job.
Fix issue with last pass allowance not being converted when project units changed.
Toolpath list: Set horizontal scroll position to the beginning for toolpaths with long names.
Fix renaming of duplicate toolpaths on some occasions.
Fix various crashes in text line splitting, on software startup, and on opening file with corrupted toolpath data.
Fix tiled toolpath cut starting in a negative position.
