Adhesive for sign foam.
What is a good adhesive for sign foam? I tried Gorilla crazy glue and Gorilla wood glue without success.
Phil
Phil
- Leo
Re: Adhesive for sign foam.
I have used Lords 2 part epoxy with amazing results.
Lords 2 part epoxy bonds just about anything.
I get the epoxy from McMaster.
Gorilla glue (polyurethane glue) is also very good but you have to clamp it really well
Wood glues just do not work at all
- ChrisInEstes
- Model of CNC Machine: Vytek 4' X 8' - Perske Spindle - Mach3
I've glued lots of HDU together using Gorilla polyurethane glue and haven't had a failure in 20+ years. What's going wrong with the glue? What's your procedure?
Chris
Chris
I'm using Gorilla wood glue. I proceed just like gluing wood- be sure the HDU is clean, apply glue and clamp.ChrisInEstes wrote:I've glued lots of HDU together using Gorilla polyurethane glue and haven't had a failure in 20+ years. What's going wrong with the glue? What's your procedure?
Chris
Gorilla Wood Glue & Gorilla Glue (polyurethane) are completely different products, I don't but I would be OK using the polyurethane as Chris does or they do an epoxy which would also do. I buy most of my adhesives from a UK Company who supply the sign industry with a range of adhesives, they manufacture themselves so if I am ever unsure about bonding different materials I know I can get a straight answer from them & not some salesmans blurb
What are you trying to glue it to? 3m makes really good spay adhisives in different strengths for different substrates.
https://www.3m.com/3M/en_US/company-us/ ... 7497&rt=r3
Dan
Dan
- ChrisInEstes
That's probably the issue right there. I use Gorilla Original Polyurethane glue, not the newer wood glue.Phil wrote:I'm using Gorilla wood glue. I proceed just like gluing wood- be sure the HDU is clean, apply glue and clamp.ChrisInEstes wrote:I've glued lots of HDU together using Gorilla polyurethane glue and haven't had a failure in 20+ years. What's going wrong with the glue? What's your procedure?
Chris
Chris
- Leo
ANY wood glue will NOT work on HDU. Do NOT use wood glue, no matter who makes it.Phil wrote:I'm using Gorilla wood glue. I proceed just like gluing wood- be sure the HDU is clean, apply glue and clamp.ChrisInEstes wrote:I've glued lots of HDU together using Gorilla polyurethane glue and haven't had a failure in 20+ years. What's going wrong with the glue? What's your procedure?
Chris
Use the regular Gorilla Glue - the stuff that foams up - it is the Polyurethane glue.
That stuff is almost the same as the HDU itself.
Works very well when gluing HDU to HDU.
The Epoxy I mentioned is a stronger glue and bonds to anything.
I often use alupanel as a substrate.
Gorilla glue does not bond HDU to Alupanel very well, so I use Lords Epoxy.
That's actually a very good point Leo, no one has actually asked what Phil is bonding the HDU to
The main reason I use he company I do is because I can phone them, tell them what materials I want to bond & they will tell me what to use. Doing any kind of commercial work I can't afford to have stuff falling down
- stephenr
- Model of CNC Machine: Shopbot PRS Standard 48x96
Hi Leo,
What Mcmaster or Lords part number do you have for the Lords epoxy?
Thank you,
Stephen R.
Thank you,
Stephen R.
- Leo
I don't have the package any longer.
I just searched epoxy and selected the clear. The description tells you what it works on.
The brand Lords, was recommended by a local professional sign maker I know.
- stephenr
Ok, thank you Leo.
Stephen R.
Stephen R.
I was gluing HDU to HDU. I used epoxy and it worked fine. Yellow wood glue worked well also.
Phil
Phil
