Allowance Offset
Allowance Offset
Postby highpockets » Thu Mar 14, 2019 4:19 am
I'm having a senior moment here.... :oops: Using the Profile Toolpath I can't seem to get the Allowance Offset to work. No matter what I try it's grayed out. What am I missing?
Re: Allowance Offset
Postby Rcnewcomb » Thu Mar 14, 2019 5:36 am
You cannot do an offset when profiling ON the vector.
Postby highpockets » Thu Mar 14, 2019 5:50 am
Rcnewcomb wrote:You cannot do an offset when profiling ON the vector.
Yea, I know that, sorry about the pic was just on the ON vector option when I took the screenshot. I've tried Outside, Inside, Climb and Conventional cuts. Nothing seems to work.
Postby StuC » Thu Mar 14, 2019 9:11 am
Do you happen to have 'Sharp internal corners' set as an option? If so this will prevent the allowance being used and might be why you are unable to use this option.
StuC
Vectric Staff
Model of CNC Machine: Craft CNC
Postby highpockets » Thu Mar 14, 2019 5:10 pm
StuC wrote:Do you happen to have 'Sharp internal corners' set as an option? If so this will prevent the allowance being used and might be why you are unable to use this option.
Thanks!!! That did the trick...
Return to Aspire - General
