multiple spindles selection
Postby bevins » Mon Mar 11, 2019 1:43 pm
I think I know the answer to this.
Is there a way to select a spindle depending on which tool. For example:
tool 5 uses spindle 2 and tool 6 uses spindle1.
Will need to edit the post but is this possible. I don't see any means of ding it in tool database.
bevins
Re: multiple spindles selection
Postby bevins » Mon Mar 11, 2019 1:50 pm
I will explain further a bit about the machine.
I retrofitted a Biesse 346 with 43 drills and three spindles to linuxcnc.
Everything is working except I have no way to turn off the drill motor except without a button. It needs to use a second spindle control which means I need the Aspire post to select a spindle in this manner.
M3 S18000 $1
That would need Aspire to be able to select a spindle for a certain tool.
Is this possible?
bevins
Postby ger21 » Mon Mar 11, 2019 1:56 pm
You should create a custom M6 macro that does what you need, based on tool number.
That's how I've seen this done with Mach3 conversions of Biesse and similar machines.
ger21
Postby bevins » Mon Mar 11, 2019 2:03 pm
I converted my machine already. I don't use Mach3. I use linuxcnc.
I need Aspire to select a spindle depending on the tool used. I don't think iot can do it, but its worth a try to ask.
bevins
Postby ger21 » Mon Mar 11, 2019 2:29 pm
I know what you use.
You don't need Aspire to pick the spindle based on the tool, you need LinuxCNC to do it.
That's what I was trying to say.
ger21
Postby rscrawford » Wed Mar 13, 2019 3:16 am
Aspire will just output a variable for tool 5 or tool 6. In LinuxCNC you will need to create a macro that does what you need it to when the g-code calls for tool 5 or 6.
Russell Crawford
rscrawford
Postby bevins » Tue Mar 19, 2019 12:49 pm
I have it done in linuxcnc but couldn't do it without changing the PP. After analyzing the situation the best solution was to have the controller handle the spindle selection based on the tool#. It would have been a large undertaking as the controller interpreter would have to accommodate for this change also. So its done and on to the next project.
Thanks guys,
Bob
bevins
Return to Aspire - General
Users browsing this forum: ssflyer and 5 guests
