I refer to my topic in V-carve forum and need help in order to find out why my generated g-codes gives a different machining toolpath than it was shown in the v-carve softvare.
http://forum.vectric.com/viewtopic.php? ... 98#p228998
Are there anybody here who can help me with this issue?
Rotary job issue. Need help.
Re: Rotary job issue. Need help.
It's hard to tell by the picture...at first it looked like it might of been rotated 90° in your preview picture, but then again the picture is hard to see. If the rotary rotates once before it starts, I would think you would need to calibrate the A-Axis. Remember it is in degrees rather than inches or millimeters.
Gary
Gary
- jaru-eri
- Model of CNC Machine: Taig and router, Gecko G540, Mach3
I found a solution for this problem. It was something with the config. setting in Mach3. I got some advice about that setting from a member in cnc-zone that was wrong.
We look forward to seeing some of your new projects on the rotary.I found a solution for this problem.
