Beki - 2 sided machining
Recently Beki posted an excellent tutorial modeling and machining a 2 sided Celtic spoon. I think it was in the Vectric Lab. I can't find it now. If someone can point me to it I would be appreciative.
Phil
Phil
- highpockets
Re: Beki - 2 sided machining
Thanks, John but the links aren't working.
Phil
Phil
- highpockets
- SteveNelson46
Did you go to the user group meeting last year Phil, think the one you are thinking about was done then so would be on the USB stick you took away with you
No, I did not go to the latest user group meeting. Beki posted a video tutorial a week or two ago that demonstrated modeling and machining a two sided spoon. She demonstrated how to use the vectors available in the Weaves folder provided in the Aspire Clipart. She added a heart to the spoon. I thought this was the best video I have seen for handling the machining a two sided project.martin54 wrote:Did you go to the user group meeting last year Phil, think the one you are thinking about was done then so would be on the USB stick you took away with you
Martin, does my description of the tutorial match the demonstration at the user group meeting?
Phil
Phil
Was it this one? https://release.vectric.com/lovespoon
Yes that's the same one from the user group meeting Phil
- Vectric Staff
- Model of CNC Machine: Various
Hi Phil,
Apologies for my lack of response, I've been away in the forest all weekend and therefore had a limited amount of data coverage (like being back in the olden days ) so have not seen this until now.
I see Adrian has linked you up to the tutorial (thanks for this Adrian )
Beki
Beki
Beki
Senior Application Engineer - Vectric Ltd.
