I am setting up to make Celtic Broaches. The material is .25" thick set on top of a .25" spoilboard. I plan to 3D machine the design to a depth of .25" with a .125 round nose bit. I have set up tabs to hold the work in place. However, I would like to cut into the spoil board about .03" so remove the edges from the perimeter of the design. How can I make the .03" cut into the spoilboard?
Phil
3d Machining Question
- highpockets
Re: 3d Machining Question
Phil,
Add .03" base height to the model and set the material thickness to .28".
Thanks.highpockets wrote:Phil,
- adze_cnc
Wouldn't this be presuming the Z zero is at the top of the material? If the Z zero is set to the machine bed, and with material exactly 1/4" thick, you'd get a flat area on the top of the design and a "plinth" of 0.03".highpockets wrote:Add .03" base height to the model and set the material thickness to .28".
Highpockets suggestion worked perfectly.
Phil
Phil
