Problems with a large 3D relief carving
Re: PROBLEMS WITH A LARGE 3D RELIEF CARVING
Postby jssussex@gmail.com » Fri Mar 08, 2019 4:54 am
I'm following your recommendations and re creating the whole project. It worth the effort to remove any possible variables. You responded to my PM but now it appears I can't read PM's
so I'll ask you to copy your reply here too.
Your Recommendations:
1. fix the machine issues
in process
2. clean up the vectors -
Yup part of the rebuild of the models.
3. re-create the 3D components using a higher modeling resolution setting. Sometimes it helps to create the individual components in separate files at very high resolution, and then import them into the current project.
I now know how to increase the resolution and will save each component as it's own .3dclip and .crv3d and then create the new model these individual components.
4. Adding a draft angle to components will help them machine better vs vertical walls.
This is what I don't know how to do
jssussex@gmail.com
Model of CNC Machine: Legacy Maverick 3X5
Re: Problems with a large 3D relief carving
Postby mtylerfl » Fri Mar 08, 2019 6:05 am
The software manual explains Draft and how it is applied. A quick look-up will help you (it’s easy).
Postby jssussex@gmail.com » Sat Mar 09, 2019 2:00 am
mtylerfl wrote:The software manual explains Draft and how it is applied. A quick look-up will help you (it’s easy).
I have accessed the online user guide and cannot locate any discussion on draft. I've mastered other skills so once the process is explained I'm sure I'll be able t o implement it. I'm not doing any new components/models until I understand this step.
jssussex@gmail.com
Postby mtylerfl » Sat Mar 09, 2019 2:20 am
Copied from the Manual...
Add Draft To Model
For some applications it can be useful to eliminate vertical walls on 3D models, especially if the machined part is intended to be used as the basis for a mold or vacuum forming tool.
The Add Draft tool will automatically add a minimum angle to any steep walls that exist in your model. The draft angle is specified by using the slider or entering a typed value in the form.
When the Apply button is pressed, the tool creates a new 3D Component by baking the visible Components and applying the draft angle across all the walls of the composite model. Note that you do not select the Component/s to apply the draft angle to, just ensure that they are visible in the 3D view. The resulting Component will not have any wall angles that are steeper than the specified draft angle. Once complete, both the original Component/s and the new Component will be visible, although the original may be obscured by the new Component. The Component with the draft angle will be named appropriately indicating the amount of draft that was added. The images below show how a Component looks before and after adding 20° of draft.
Postby mtylerfl » Sat Mar 09, 2019 2:25 am
When you open the HTML Online Manual, you will see a menu bar at the bottom of the screen.
Click on the menu item "Single Page". This opens the entire software manual as one looong page.
To search for a topic/item/subject, just press Ctrl+F to open the standard browser search box and type in what you want to search for.
Postby jssussex@gmail.com » Sat Mar 09, 2019 2:37 am
Another AHA moment, I've seen that icon but never clicked on it. Thank you I never understood what 1 page met... now I can search the whole manual..... THANK YOU
Also I had seen the draft icon but it never processed and never clicked on it. You are correct this is a very simple process. Thanks so much. I can now contiune on my journey of a 100,000 steps LOL
jssussex@gmail.com
Postby mtylerfl » Sat Mar 09, 2019 2:44 am
You are welcome! I try to encourage people to check the manual when a question presents itself. It is very, very thorough and covers every feature of the software.
Postby Chuck Keysor » Tue Mar 12, 2019 5:52 am
Hello Jim. I may be a day or two late with this. But last time I was struggling with the eternal resolution problem for a large carving design, I made a set of figures that I could refer to to help me figure this out, the next time I needed to figure this out again. These figures show the simulations of various combinations of resolutions and work space size, and it all comes down to how many pixels per square inch you have. If you have a small job size, well then you can go to a lower resolution in order to get the level of detail (ie pixels per square inch) that you want. I hope these figures help. Chuck
High
Very High
Extreme
Maximum
Chuck Keysor
Model of CNC Machine: Shopbot PRT alpha 60 x 148
Postby Adrian » Tue Mar 12, 2019 11:43 am
It's also fully interactive so you can click on the Modeling tab picture on the first page and then click on the Draft icon to drill down into that section.
Postby jssussex@gmail.com » Mon May 20, 2019 8:54 pm
I thought I would post the resultfor the many people who took the time to provide suggestion that resulted in a huge improvement to this carving. I do not know how to tag people to say thank you but I'd like to thank personally dealguy11, Rcnewcomb, TReischl, mezalick, martin54, mtylerfl and Chuck Keysor. Not only did you help me but this thread will help other in the future.
I did go back through my models and redo each component in 25X at actual size or larger. I have a new computer so the file and tool path generations were not terrible. When this was completed I had made 6 half-size MDF carvings at various stages in the process as well as one full size MDF carving and one "failed" Walnut model (ouch) and this final model. Taking it a step at a time, using the tutorials from Vectric and these experts suggestions I finally persevered. Even after it carved I could see where I make improvements on my next large model.
jssussex@gmail.com
Postby Rcnewcomb » Mon May 20, 2019 9:48 pm
That is part of the risks of the art: I complete something and everyone says "ooo and ahh", whereas I can only see the problems that I want to avoid in the next project.
Postby TReischl » Mon May 20, 2019 10:25 pm
That looks really good!
Thanks for getting back to us and letting us know how it turned out.
That is a lot of carving.
Previous
Return to Aspire - General
Users browsing this forum: No registered users and 15 guests
