3D Daisy
3D Daisy
Postby Les_linton » Tue Feb 12, 2019 1:36 am
Good evening everyone,
Been quite a while since I have been on here and really just getting back into working with my machine for anything but 2d cutting. Have upgraded to 9.5 so I'm current and struggling with a project. Since most of the 3D work I've done has come from projects from Design & Make, I am not nearly as proficient with Aspire as I need to be. I have a file with all/most of the detail done on a daisy for a stair part, I just can't seem to get things to blend and would appreciate any help I can get. I am attaching the file as I currently have it. The issue is the size and the double layer of petals. I have backed almost everything out but left the top layer of petals in what I think is a raised position. Not sure if I did it correctly because when I try to get the toolpath it is not what I expect.
Thoughts,
Les
Stair Part.crv3d
(625.5 KiB) Downloaded 67 times
Les_linton
Model of CNC Machine: ViperX7
Re: 3D Daisy
Postby jimwill2 » Tue Feb 12, 2019 3:59 am
I just copied and pasted the daisy layer you already had made. Then rotated them, moved the copies to beneath the originals in the modeling tab and set both to merge. I raised the base on the originals .0625". Something to play with. Have fun.
daisy.crv3d
(1.48 MiB) Downloaded 61 times
Jim Williams
jimwill2
Model of CNC Machine: CaMaster Stinger w/recoil, FTC
Re: 3D Daisy
Postby SteveNelson46 » Tue Feb 12, 2019 3:25 pm
Maybe something like this? I deleted all but one petal and set it to merged. Then I opened the properties dialogue box and applied some tilt. Then used circular copy. Lots of variations are possible.
SteveNelson46
Model of CNC Machine: Camaster Stinger with Recoil Lathe
Re: 3D Daisy
Postby Les_linton » Wed Feb 13, 2019 12:52 am
Steve, Thanks for taking a look. My drawing was based off a very old plinth block my friend found in an old house and are looking at staying with that pattern. I like what you did though.
Jim, I think you may have gotten me off center. I still have a lot to do for the finished product and I will likely be back getting more advice from the forum. I need to cancel Dish and spend my time here. Many thanks to both of you,
Les
Les_linton
Return to Aspire - General
Users browsing this forum: ger21 and 24 guests
