Help to Export Vectors from ArtCAM file
Postby Gerald Martin » Thu Feb 07, 2019 4:15 am
I have an ArtCAM file I'm wonder if someone would be willing to open and export the vectors from? I have a 2002 ArtCAM Insignia license - right now, I don't have an old computer here running Windows XP that I could attempt to install and use the software.
Here is a download link to the file on my Nextcloud server: https://cloud.martinsautosvc.com/index. ... Ha6HQL2kMw
Would appreciate if anyone is willing to help.
Gerald
Gerald Martin
Model of CNC Machine: ShopBot PRS Alpha 96-60
Re: Help to Export Vectors from ArtCAM file
Postby Bob Reda » Thu Feb 07, 2019 12:12 pm
There is something on aspire that allows you to save artcam files For the life of me I cant find it now, and I did it, someone will chime in. It will import it and change it to a 3d clipart file
Bob
Bob Reda
Postby phill05 » Thu Feb 07, 2019 1:10 pm
Bob Reda wrote:There is something on aspire that allows you to save artcam files For the life of me I cant find it now, and I did it, someone will chime in. It will import it and change it to a 3d clipart file
Bob
I too would be interested in this as I have a A/C file I would like to convert to use in Aspire.
Phill
phill05
Model of CNC Machine: Hybrid re-build
Postby garyb » Thu Feb 07, 2019 2:10 pm
Gerald Martin wrote:I have an ArtCAM file I'm wonder if someone would be willing to open and export the vectors from? I have a 2002 ArtCAM Insignia license - right now, I don't have an old computer here running Windows XP that I could attempt to install and use the software.
Gerald
Here you go Gerald, your vectors exported in dxf, if you prefer eps let me know
Gary
dhw mdf clock vectors.zip
exported dxf
(1.65 MiB) Downloaded 20 times
Beckwith Decor Products
Custom CNC Tooling/Onsrud Distributor
http://www.beckwithdecor.com
garyb
Postby Adrian » Thu Feb 07, 2019 2:25 pm
Bob
You can export in STL and grayscale relief from Aspire both of which ArtCam can read but there is no way to read ArtCam files directly into Aspire that I am aware of as it's a proprietary format.
Postby garyb » Thu Feb 07, 2019 3:32 pm
Aspire and Artcam are both the same as both use their own proprietary file formats, both export and import stl format for file interchange with relief models. The catch is you need both programs to do in house or someone willing to export the file in a format you can import, such as stl.
Gary
garyb
Postby Bob Reda » Thu Feb 07, 2019 4:17 pm
When artcam went belly up vectric did have a way to import the rlf files to aspire but I can't seem to find it anymore. I did it, so I'm guessing I was not dreaming it. Maybe they removed it in one of the updates.
Bob
Bob Reda
Postby mtylerfl » Thu Feb 07, 2019 4:23 pm
Bob
Bob Reda wrote:When artcam went belly up vectric did have a way to import the rlf files to aspire but I can't seem to find it anymore. I did it, so I'm guessing I was not dreaming it. Maybe they removed it in one of the updates.
Bob
Aspire and VCarve can indeed import ArtCam version 9 .RLF models (this is the format James B requested from me prior to conversion to Aspire format and generic STL, many years ago).
Although, this may be a moot point as it relates to the original thread topic of just needing vectors!
Postby Gerald Martin » Thu Feb 07, 2019 7:24 pm
Hi Gary, that is super helpful. DXF is fine, EPS might support bezier curves though which would be better than just arcs and lines.
Do you mind seeing if the toolpath data can be turned off and only get me the vector outline of the artwork? I will have Aspire redo the v-carve toolpaths. Also I did not know that i shows 6 of the clock plaques, I only need one...not sure if this will save you any time, it's fine either way.
Thank you so much!
Gerald
Gerald Martin
Postby adze_cnc » Thu Feb 07, 2019 9:51 pm
Gerald,
Try this: splines, EPS, no toolpaths.
DXF didn't preserve splines (DXF should be renamed LCD).
Steven
illinois (splines).eps
(114.88 KiB) Downloaded 10 times
adze_cnc
Postby Gerald Martin » Fri Feb 08, 2019 12:53 am
Wow. That's great. So very helpful, both of you! Thanks so much!
Gerald
Gerald Martin
Return to Aspire - General
Users browsing this forum: No registered users and 28 guests
