Need help with edge shape
Postby woodstripboats » Tue Feb 05, 2019 6:44 pm
Would someone be willing to help or set me in the right direction . :?: I have this 7"by 7" square post that I'm trying to put a edge shape on. The shape needs to be at 45 deg. to the face. See attached Aspire 9.5 file.
thank you
THE POST corner details.crv3d
(1.42 MiB) Downloaded 11 times
photo of shape
woodstripboats
Model of CNC Machine: Shopbot PRS Alpha 60 x 96 x 12"
Re: Need help with edge shape
Postby TReischl » Tue Feb 05, 2019 8:30 pm
If you only have a few to do I would lay those notches out and remove them with a sharp chisel.
That said, the next thing I would do is build a fixture to hold the pieces at a 45 degree angle so I could run a 90 degree bit straight across them.
Hopefully your machine has enough Z axis and bridge clearance to do that.
http://www.tedreischl.com
Low Profile CNC Router Vise
Postby mtylerfl » Tue Feb 05, 2019 8:53 pm
woodstripboats wrote:Would someone be willing to help or set me in the right direction . :?: I have this 7"by 7" square post that I'm trying to put a edge shape on. The shape needs to be at 45 deg. to the face. See attached Aspire 9.5 file.
thank you
Just use a 90° Bit assigned to either Pockets or Offset vectors drawn where you want the chamfers. Several of the Free Projects use this technique. (Take a look at the Pineapple project for just one example).
Postby woodstripboats » Wed Feb 06, 2019 5:25 pm
Thank you for the reply
TReischl there are a lot of these to carve so my trusty chisel is not a realistic option. I have considered fixturing the pieces at 90 deg. but that would be a last resort. I do have a 12" Z axis however.
MTylerfl I have tried that method but as you can see in the attached photo it doesn't seem to work. The 90 deg vbit tapers the chamfer on the ends. The face side of chamfer needs to be 1.625" at a 45deg to the two faces.
Is there another way? Am I missing something obvious?
thanks for your help and input, very much appreciated.
Charlie
woodstripboats
Postby mtylerfl » Wed Feb 06, 2019 5:27 pm
Post your file here, Charlie, so we can take a look.
Or, contact support@vectric.com and send them the file along with a link to this thread so they can see what you’re after.
Postby woodstripboats » Wed Feb 06, 2019 5:46 pm
thanks Michael; the shape file for the 7" by 7" post is attached in my first post. It is just part of a larger drawing shown here in this DXF attachment.
THE POST.dxf
(277.75 KiB) Downloaded 9 times
woodstripboats
Postby adze_cnc » Wed Feb 06, 2019 6:48 pm
Nice DXF file I guess. Doesn't help figuring out what toolpaths you have already tried to effect the preview images.
See attached file for method to get the end of the chamfers correct. Now you just have to figure how to do the long face between them.
post_end-chamfers.crv
(39.5 KiB) Downloaded 6 times
adze_cnc
Postby mtylerfl » Wed Feb 06, 2019 6:56 pm
Hi Charlie,
When we ask for your file, we always mean your Vectric project file, except in very rare cases when something else is specifically noted.
So, may we see your Aspire file? If too large to post here, use DropBox, post the download link, etc
Postby woodstripboats » Wed Feb 06, 2019 8:07 pm
Getting the 1.625 across the chamfer is exactly one of the issues. I have tried a Vbit ; To get the shapes I have also tried a single line sweep as well as a double line sweep. Thought that if I could get the shapes then could just machine it with a ball nose.
Thanks for looking at this.
Charlie
THE POST corner shapes trials.crv3d
(838.5 KiB) Downloaded 7 times
woodstripboats
Postby woodstripboats » Wed Feb 06, 2019 9:58 pm
OK After a large cup of coffee I think that this will work.
Thanks to everyone who took the time to look at this and offer suggestions . Much appreciated!
Never underestimate the power of the two rail sweep!
Charlie
woodstripboats
Return to Aspire - General
Users browsing this forum: RebeccaJ, StuC and 12 guests
