Make a snake
Make a snake
Postby Wayne Locke » Fri Jan 25, 2019 7:09 pm
Can someone chime in with their ideas for designing and cutting a snake like this. It will be about 20 to 24 inches.
Wayne Locke
Re: Make a snake
Postby Rcnewcomb » Fri Jan 25, 2019 7:15 pm
Buy the Rod of Asclepius clipart from Design and Make. I cut this for a physician about 3 months ago.
Re: Make a snake
Postby garylmast » Fri Jan 25, 2019 7:36 pm
The other day I was playing around with Aspire's Clipart by merging and copying it to the other side and doing a double-sided, weird looking walking stick. Also, years ago, I did a walking stick using Aspire's Clipart but modeled it in Rhino and use the Rotary to cut it, but something like that could also be made doing the double-sided project.
Gary
garylmast
Re: Make a snake
Postby Wayne Locke » Fri Jan 25, 2019 8:45 pm
I need to make an actual shaft with the snake to function as a ceremonial mace.
Wayne Locke
Re: Make a snake
Postby jarm2 » Fri Jan 25, 2019 8:49 pm
This is a version of the Veterinary Symbol I designed to carve for a local veterinarian(sp). I never did carve it, but plan to one of these days.
Vectric Aspire, Cut3D, VCarve Pro, AutoCAD lite, Draftsight, Corel Draw X6, ViaCAD Pro 9, W 10
jarm2
Model of CNC Machine: C&CNC electronics
Re: Make a snake
Postby Rcnewcomb » Sat Jan 26, 2019 12:11 am
Model the snake and the stick separately.
Then snipe and tilt the snake model where you want it to appear to go behind the stick
Re: Make a snake
Postby garylmast » Sat Jan 26, 2019 1:14 am
CG Trader has a 3-D model for $9.00. You can do a double-sided project with it to make a ceremonial mace. http://www.cgtrader.com/3d-print-models ... rint-model. Or you can do what Randall suggested and then copy the object to the other side and do it as a double-sided project.
Gary
garylmast
Return to Aspire - General
Users browsing this forum: No registered users and 17 guests
