2d view question
2d view question
Postby Fivetide » Thu Jan 24, 2019 6:37 am
Hi I want to put a single vector along the Y axis and use the same vector to control the varying depth of Z but I cant work out how to flip the 2d drawing so I can do this. Could anyone help ?
Fivetide
Model of CNC Machine: BLACK CAT 6090
Re: 2d view question
Postby highpockets » Thu Jan 24, 2019 6:47 am
Try using the Fluting Toolpath....
Postby Fivetide » Thu Jan 24, 2019 7:13 am
highpockets wrote:Try using the Fluting Toolpath....
Thanks highpockets, I looked at the fluting and again couldn't work out how to bring a shaped vector I have drawn in Auto cad to control the Z height along the Y cut
Fivetide
Postby highpockets » Thu Jan 24, 2019 7:56 am
Sorry I didn't completely understand what you are trying to do. I'm still not real clear, can you post a picture or two?
Postby highpockets » Thu Jan 24, 2019 8:20 am
Am I on the right track?
Postby Fivetide » Thu Jan 24, 2019 7:06 pm
Hi yes I need to explain it a bit better sorry : imaging you have a 3d carving of a face on a board, I just want to carve one of the vectors along the Y or X + the 3d heights on the Z . In other words I want to draw a single vector of various heights and curves etc (the Z), and project it along the X or Y. A single vector of the 3d model.
Fivetide
Postby highpockets » Thu Jan 24, 2019 7:11 pm
Nope, still confused. :oops: :oops: :oops:
I'm not understanding the 3D model and what it has to do with a single vector.
A picture/sketch, something would help. Sorry to be so dense.
Postby martin54 » Thu Jan 24, 2019 7:15 pm
[quote="highpockets"]Nope, still confused. :oops: :oops: :oops:
Don't worry John your not the only one :lol: :lol: I am not sure if the OP just wants to project a vector cut onto a 3D model or if they want to try & generate a vector from the 3D surface :oops: :oops:
Postby mtylerfl » Thu Jan 24, 2019 7:17 pm
I can’t decipher the description either, unfortunately.
Yep...a sketch may help.
Postby highpockets » Thu Jan 24, 2019 7:20 pm
mtylerfl wrote:I can’t decipher the description either, unfortunately.
Thank You Michael.... I though I was just being dense :lol: :lol: :lol:
Postby eph210 » Thu Jan 24, 2019 8:17 pm
I think that it is one of two possibilities that you are after.
If you already have the 3D model you can do it as follows:
Draw a straight line vector in the direction and position on the model as required.
Make sure that the model is visible in the 3D view.
Use profile on tool path with a depth of cut of 0.00 and make sure that project onto 3D model is checked.
That will give you a toolpath that follows the model in the Z direction
The other possibility is:
Make sure the model is visible
Go into the measurement tool and select model cross section.
Click a start point and an end point and the software will compute a cross section vector for that point.
That will give you a vector that follows the shape of the model at the specified point.
I hope that helps
Euan
eph210
Model of CNC Machine: Stinger 1 and Mabel, both with 4 axis
Postby Fivetide » Thu Jan 24, 2019 8:44 pm
Maybe it would be better to explain why I want to do what I’m asking. I have made my own wood lathe spindle copy attachment. (see picture please) It only uses the Z + X axis, its not a rotary machine as I’m using the existing DC motor to turn the blanks. So - to cut out a spindle leg I only need the shape of the leg along the X axis and its corresponding height using the Z axis. If I where to draw the spindle leg in vectric I would use a single vector as the shape and then wrap it around the cylinder. So I’m attempting to trick the machine into thinking it’s a flat block of wood that I’m essentially trying to cut a single straight groove along the top (X) out. So in the below attachment it would be just that single shaped vector along (X) and down (Z) into the wood blank.
I hope this explains it as I have no idea how to explain it anymore lol
Fivetide
Postby adze_cnc » Thu Jan 24, 2019 8:55 pm
Now that we can see what you see...
Hey John: How about a moulding toolpath that only generates one pass?
Steven
adze_cnc
Postby highpockets » Thu Jan 24, 2019 9:58 pm
Steven, I think you're right. But then I've been confused all along on this one :lol: :lol: :lol:
Postby adze_cnc » Thu Jan 24, 2019 11:22 pm
The "Swept Profile" a.k.a. moulding toolpath gives me a headache every time I use it.
It won't work in this case.
The only thing I can think of is model the spindle as a narrow 3D component and do a 3D finishg toolpath on it such that it only generates one line.
See attached VCarve v9.512 file.
Steven
copy-carver.crv
(131 KiB) Downloaded 34 times
adze_cnc
Next
Return to Aspire - General
Users browsing this forum: mcurtis and 27 guests
