Job Setup
Job Setup
Postby KSully » Sun Jan 20, 2019 5:48 pm
Is there away to set a circle up in the job setup? This came up recently and I don't think there is away
KSully
Model of CNC Machine: ShopBot PRS 48 96
Re: Job Setup
Postby Adrian » Sun Jan 20, 2019 6:28 pm
The job is always a rectangle.
Out of interest why would you need it to be to be a circle?
Re: Job Setup
Postby dhellew2 » Sun Jan 20, 2019 8:31 pm
I am curious too.
It does not matter what shape the layout page is, you can create any shape you want on the square/rectangle page.
Machines are square/rectangle and the drawing page is similar to the shape of the machine.
More information would make it possible to give more help.
Dale
Dale
dhellew2
Re: Job Setup
Postby KSully » Mon Jan 21, 2019 3:24 am
Sorry should have been clear. I have a round piece I need to do some work on. I have a 3.5" circle I need to cut a .125 grove in at 1". Going to be a problem. Maybe I could set my zero in the center and just make the setup square. Think that would work?
KSully
Re: Job Setup
Postby gkas » Mon Jan 21, 2019 4:44 am
It will work fine. Just define your job size to be > 7", with the XY Datum Position to be the center. Mark the center of your round piece, set the xy=0 there, and you're ready to go.
gkas
Model of CNC Machine: Axiom AR8 Pro+, Axiom 4.2W Laser
Re: Job Setup
Postby KSully » Mon Jan 21, 2019 9:45 pm
Thanks for your help worked great!!
KSully
Return to Aspire - General
Users browsing this forum: Adrian, Google [Bot], TReischl and 26 guests
