Cleaning up a 3D finishing cut
Postby Phil » Sat Jan 19, 2019 4:00 pm
I am working on an arch for casing on a half round window. After completing the finishing pass I want to clean up the shoulder pointed to in the attachment. I tried using the vector that was used for the finishing tool path. I selected the vector, the profile toolpath - outside and offset by .01, that didn't work, I tried offset by .02, .03, .04. The offset didn't move the tool closer to the edge of the shoulder, it didn't move it away either.
I'm looking for a way to clean of the edge of the shoulder- suggestion?
Phil
Phil
Re: Cleaning up a 3D finishing cut
Postby Mike-S » Sat Jan 19, 2019 4:46 pm
Depth of cut set correctly?
Mike-S
Postby Phil » Sat Jan 19, 2019 5:23 pm
Yes.
Phil
Postby 4DThinker » Sat Jan 19, 2019 8:13 pm
If you want to move closer to material to "clean up" a cut, Allowance offset should be a negative number. At least with the profile and pocket toolpaths.
4D
4DThinker
Postby Phil » Mon Jan 21, 2019 2:58 pm
Thank you Mr. 4D.
Phil
Phil
Return to Aspire - General
Users browsing this forum: No registered users and 31 guests
