Name in Rolling Pin
- Mark's Wood Chips
- Model of CNC Machine: ShopSabre 23 with Rotary
Name in Rolling Pin
I have been asked to carve a name into a rolling pin so that the pie crust would bear the maker's name. I have a rotary axis and have made plain rolling pins but I have a question for anyone who may have tried to transfer a pattern that works with rolled pie crust. I plan on creating a mirror image of the text but I want to know if I should V-carve this or create a profile tool path using a ball nose bit. Have any of you attempted this? If so, what kind of tool path releases the dough best when rolled?
- mtylerfl
Re: Name in Rolling Pin
Hi Mark,
I've not done that myself, but there was a recent Blog from CarveWright that is a similar idea (Embossed Rolling Pins):
http://www.carvewright.com/category/carvewrightblog/
Of course, the methods of getting the models to wrap for rotary won't really apply to any other CAM software (since they use a proprietary system), but it might serve for inspiration and ideas for you.
As far as dough release, you could apply a Draft Angle to just about any model that will help facilitate that. Otherwise, a VCarve toolpath should allow the dough to release fine, due to the "automatic" draft angle.
- Mark's Wood Chips
Thank you Michael, that website gave me a good starting point. Interesting stuff on that site.
Mark
Mark
- mtylerfl
You’re welcome, Mark. I thought you might enjoy that!
I did a rotary project with lettering a few months ago:
http://forum.vectric.com/viewtopic.php? ... er#p219528
For the lettering I used a v-Bit. First go around the lettering looked good in the preview but once machined, the letters came out mirrored, so I mirrored the letters before machining and they came out fine. Later on, I turned the rotary's head to the foot of the CNC machine and that solved the mirroring problem.
Gary
Gary
I used Vcarve with 1mm conical ballnose (IIRC, it is a while ago) and a small end mill to carve the flat bottoms. But I am sure an engraving bit or e.g. 30 degree v-bit would work as well.
