Computer Mouse with regards to Node Editing
Desert_Woodworker
Post by Desert_Woodworker »
After a session “node editing” madness- clicking the mouse on the nodes multiple times and not being able to get it to “catch” (getting it red) so that I could edit…
Question: What is the best computer mouse to use with node editing or does it matter?
dealguy11
Re: Computer Mouse with regards to Node Editing
Post by dealguy11 »
I've always used standard 2 button mice with a scroll wheel, both Microsoft and Logitech, with no problems. If clicks aren't catching and battery in the mouse it good and there's nothing blocking the transceiver, may be time for a new mouse.
SteveNelson46
Post by SteveNelson46 »
I use a Logitech wireless Master MX 2S 3 button (scroll wheel is middle button). It has a lot of programmable buttons but I have most of them turned off. I agree with Steve, Any good 3 button (2 + wheel) mouse will work.
LittleGreyMan
Post by LittleGreyMan »
Draw a simple circle and check if node editing works OK.
If it is not, it's maybe time to follow Steve's advice.
If it works with the circle, be sure you've zoomed enough in your design. When control handles are very close to the node, it may be difficult to get it selected without zooming.
Best regards
Didier
W7 - Aspire 8.517
mezalick
Post by mezalick »
You may need to zoom in a bit to "see" the actual node.
Sometimes the handles of a bezier node are so close to the node itself that it's difficult to only select the node.
You may also want to adjust the "Snapping Radius" ...( F4 )
Michael
Michael Mezalick
mm@mezalick.com
+1 to what Michael M has said, it frustrates me sometimes trying to select a single node & the only option is to zoom in closer to the node.
I have found that it makes no difference what computer I am using or which mouse I am using :lol: :lol:
Desert_Woodworker
mezalick wrote:You may need to zoom in a bit to "see" the actual node.
Michael
Thank you- it seems to help.
