See if I can explain this:
I open a new project say 8 X 10
I draw a rectangle again 8 X 10
I import a bit map to convert to a 3D component. The import and the 3D component are larger then 8 X 10
I select a corner of the 3d component adjust the size down multiple time until I can get it into my 8X10 rectangle.
Not so difficult....
Now my question. Is there a process (key stokes) to select my 3d component and hit a key
and Aspire fits the component into my 8 x 10 rectangle? Click bang done...
Component adjustment?
Re: Component adjustment?
Use the Size tool (shortcut key is T) and you can type in the values to resize the component directly.
