tap files off
tap files off
Postby lwarnell01 » Sun Dec 30, 2018 12:22 am
Good evening I have a Shark HD CNC with bosch router and while trying to run the files for the Padlock plaque in the gallery the router doesn't line up to my Zero axis. I used the touch plate to specify the zero z axis, but when i run the project the router goes all the way to the X,Y axis limit to try to start cutting. Any ideas? I did recalculate the toolpaths.
lwarnell01
Re: tap files off
Postby martin54 » Sun Dec 30, 2018 12:53 am
Have you made sure you have the correct x,y zero set? Check the set up in the file if this is a downloaded project to ensure where your setting your x y zero is the same as in the file, also might be worth checking the starting position in the toolpath set up :lol: :lol:
Re: tap files off
Postby Daniel S » Sun Dec 30, 2018 8:23 pm
Are you using the Pendant? If so use the down button to see your xyz start position for current project.
Daniel S
Return to Aspire - General
Users browsing this forum: Google [Bot], smb315 and 13 guests
