I have a board (single sided) with 3 circles that starts cutting from front to rear.
How do I reverse the order of cutting?
reverse cut order
- highpockets
- Model of CNC Machine: cncrouterparts
Re: reverse cut order
thanks high pockets!
how about turning board end for end instead (or along with) Vector selection order?
high pockets:
thanks for your suggestion. However, being so new please tell me the steps to get there, I don't see the exact words
- mtylerfl
Hi Lavon,
You can search your User Manual for details on this. Use the search term “vector selection order” (in case you don’t know, you access the search window for an html file or PDF file by pressing Ctrl-f on your computer keyboard).
The manual is accessed via your Help Menu by selecting “Help Contents”. It opens as an html file in your internet browser.
After the manual is displayed, you can go to the bottom of the page and click on the menu item called Single Page then click on the item called PDF version. It will now download and display the PDF
I like the PDF option because it has page numbers (the html version does not). This is a big plus, because I can then tell you the section you want to read is on page 140. (I couldn’t tell you that if the manual was still in the html format).
mtylertf:
THANK YOU
THANK YOU
- mtylerfl
You are welcome, Lavon.
