Feature Request: V-Carve as clearing tool
unicacher
Model of CNC Machine: ShopBot Desktop
Post by unicacher »
I have recently found the joy of v-carve inlays. Once mastered, they are quick and easy.
For production runs, however, constantly swapping between a v-carve bit and clearing bit is very time consuming. To speed things up, I use the v-carve bit as a clearing tool with a stepover that gives me enough clearance to mate the two parts. V-carve does not allow the selection of a v-carve tool for clearing, so I have to select an end mill, but leave the v-bit in the machine. This works fine, but I have to run the part to prove that enough material is removed to mate the parts.
Here's the request: Allow for selection of a v-bit for clearance tool with a warning.
Or, take it to 11: Create a gadget or setup option for v-carve inlay! (It's so much better with 2-sided machining upgrade, but every time you update, awesome new timesavers are included!)
Wayne Locke
Model of CNC Machine: Shopbot
Re: Feature Request: V-Carve as clearing tool
Post by Wayne Locke »
Do not choose”Large Area Clearing Tool” and Aspire will use the v bit with whatever step over it has.
