Help with a big mistake
cconway
Model of CNC Machine: Shark HD4 Extended/Water cooled spindle
Post by cconway »
I am making a growth chart for my granddaughter that I have not seen in months, but am going to see on Friday. I was carving in her name and foot number this morning. Someone called while I was setting things up and I got distracted and did not realize the 60 degree V bit was still in the machine when it should have been the 90 degree. The tool path was set for .25 flat with a pass depth of .125. The attached pictures shows the results. Is there any way for me to fix this since I'm not going to have enough time to redo the project? Boy do I have my fingers cross on this one.
joeporter
Re: Help with a big mistake
Post by joeporter »
If everything is still clamped down and your X Y zero's are the same, I would put in the 90 deg and run it again and see what happens.....joe
cconway
Post by cconway »
Everything is still in place, but "see what happens" makes me a little nervous. Sounds like a complete roll of the dice.
scottp55
Model of CNC Machine: ShopbotDesktop 5.5"Z/spindle/VCP11.5
Post by scottp55 »
I'm not doing anything at the moment...can you post the file as a .crv?
I'll try to duplicate a small example of a few letters using a 60, and then thinking maybe just plugging in a 60 into the toolpath will correct it(just with a larger flat area?)
IF you're trying to duplicate existing carvings...then it won't match:(
BUT maybe you could say you MADE it different because she's getting so BIG? :)
be happy to try, and post pics in BBPly.
Oh....can anyone identify the font...think I'll try just out of curiosity and guesstimate font size.
R.N.
Should be mostly ok if you run the correct tool over the top. The bottom might have some grooving in it depending on stepovers etc but the bulk of the letter will be a lot better.
I've attached a couple of previews from an older version of VCarve where it was possible to get the preview to cut with the wrong tool to see what happens. The first picture is what you've done and the 2nd is from running the correct toolpath over the top.
garyb
Post by garyb »
Sand them as go with them as they are.
treat as added detail, over the years we have done this type of thing on purpose to get different looks
Gary
Beckwith Decor Products
Custom CNC Tooling/Onsrud Distributor
http://www.beckwithdecor.com
Leo
Post by Leo »
cconway wrote:Everything is still in place, but "see what happens" makes me a little nervous. Sounds like a complete roll of the dice.
What Joe said was precisely what I was going to tell you.
It will be fine, because the 90 degree cutter will cut more than the 60.
Adrian illustrated it.
Mobius
Post by Mobius »
This. You're golden, just run it again with the right bit.
Connor Bredin
www.distinctive-concepts.ca
wb9tpg
Post by wb9tpg »
You can always go back into Vcarve and duplicate the tool path with what you actually ran. Then preview both the v60 and v90 paths together to see if you'll like it or want to adjust the v90 more.
Gary Mitchell
Kentucky, USA
cconway
Post by cconway »
Thank you to everyone for the advice. I truly appreciate it. I'm going to run the 90 degree over top and see how she looks.
