"Feature" lost in 9.5
Re: "Feature" lost in 9.5
File with the dogbones was posted a bit further up in the thread.
In shapes with corner angles greater than 90 degrees, such as a 6-sided pocket for hex nuts, I start with drawing diagonal lines from corner to opposite corner.LittleGreyMan wrote:4D, some explanations of your optimised dogbone method please?
TIA
I use the circle tool to place a circle the size of the dogbone I want, centered on each corner node.
Then I drag those circles by their center point and (previously) could snap them where the ghost perimeter intersects their associated diagonal line.
Scissor trim most of it away to leave just a minimal dogbone at each corner so the hex nut will fit in and still touch wood at each corner.
Example shown in the file I posted above.
4D
Thanks for the comment. That's what I thought, you draw the bisectrix of an angle larger than 90°. Using the ghost and snapping features for that is a pretty smart trick. Requires a little more job, but much better than the standard dogbone.
BTW guys, could you please stop mocking the guy who didn't even noticed a file was posted to answer his question…
Best regards
Didier
W7 - Aspire 8.517
Didier
W7 - Aspire 8.517
I seem to have no problems with this in 9.510. Well, it's a bit klunky trying to hit the intersection between the line and the "ghost" but that could just be the snap tolerance is really tight. And it seemed a lot easier sliding along the line and waiting for the snap on the circle to match the hexagon's vertex (former centre point of circle).4DThinker wrote:Then I drag those circles by their center point and (previously) could snap them where the ghost perimeter intersects their associated diagonal line.
Steven
What happens now 9.510, is that (zoomed in) you can see the cursor jump between following the diagonal OR the ghost of the shape you are dragging. It practically resists snapping to the true intersection as if it can't decide which crossing vector it wants to snap to there. Previously it would snap to the exact intersection easily.
I'll add that this feature only disappeared in the latest 9.510 update. I've got 9.509 on another machine and that feature does work.
4D
4D
