Dividing a circle in segments
Postby Soapyjoe » Fri Oct 12, 2018 9:05 am
Hi Everybody,
Just a very general question .... Is there a quick way of dividing a circle into segments ?
I can do this by dividing 360 by the number of segments required.... then rather laboriously drawing them out .... but do feel there must be a better method.
Your help would be appreciated.
Soapyjoe
Model of CNC Machine: Heiz
Re: Dividing a circle in segments
Postby fixtureman » Fri Oct 12, 2018 12:07 pm
I do this by drawing my circle to size then draw a .062 inch circle and use the copy along vector.
fixtureman
Postby ger21 » Fri Oct 12, 2018 12:24 pm
Draw one vector from the center, and do a circular copy.
ger21
Postby 4DThinker » Fri Oct 12, 2018 2:16 pm
Use the polygon tool. Set the number of sides to how many segments you want. Start it out at the center of your circle, then size it so it touches the circle. Where is touches the circle you can mark or trim or whatever.
4D
4DThinker
Postby martin54 » Fri Oct 12, 2018 2:35 pm
I do it the same way as ger21, draw one vector from the middle of the circle to the edge of the circle & then use the circular array tool to divide it into the required number of segments :lol: :lol:
Postby Soapyjoe » Fri Oct 12, 2018 3:26 pm
Thanks to everybody who greatly assisted me with this little problem.
I have been using this programme for several years now and never before had a need for "circular copy"..... worked wonderfully.
I needed to divide a circle into 37 segments
The forum is a great asset
Thanks once again
Soapyjoe
Postby wb9tpg » Sat Oct 13, 2018 12:19 am
I've been using line and circular copy like others but I'm wondering if a star with the same diameter would work too.
wb9tpg
Postby SteveNelson46 » Sat Oct 13, 2018 12:43 am
wb9tpg wrote:I've been using line and circular copy like others but I'm wondering if a star with the same diameter would work too.
Something like this?
SteveNelson46
Postby 4DThinker » Sat Oct 13, 2018 10:21 am
Likely more like this:
4DThinker
Postby wb9tpg » Sat Oct 13, 2018 2:37 pm
4DThinker wrote:Likely more like this:
Exactly what I was thinking but wasn't sure it'd work. Quick and easy
wb9tpg
Postby Soapyjoe » Sat Oct 13, 2018 3:20 pm
Cirular Array.crv3d
(30 KiB) Downloaded 50 times
I am using the circular copy of the line,
What I am actually making is a roulette wheel
Soapyjoe
Postby Soapyjoe » Sat Oct 13, 2018 3:33 pm
The finished Wheel will look similar to this
Soapyjoe
Postby LittleGreyMan » Sat Oct 13, 2018 4:48 pm
Soapyjoe wrote:The finished Wheel will look similar to this
If I'm not mistaken this one requires 38 segments, not 37.
BTW, using the star feature is a nice trick.
Best regards
Didier
W7 - Aspire 8.517
LittleGreyMan
Postby Soapyjoe » Sat Oct 13, 2018 11:01 pm
Hi,You are quite correct for an American Roulette wheel.... they give the punters a lower chance of winning by having two Zeros
However, I am modelling a European type wheel with only one zero.
Cheers
Soapyjoe
Return to Aspire - General
Users browsing this forum: Adrian, Will Williamson and 26 guests
