DWG File
DWG File
Postby daibeer » Thu Oct 11, 2018 10:11 am
When I load a DWG file into Aspire 8, ( its a dinosaur puzzle) the outline vectors are split into small sections. So I have to select one, select the next one and join vector with line. This will take a very long time to complete. Is there a way I can just select the whole vector drawing and do a mass join of the vectors. Thanks
daibeer
Model of CNC Machine: Heiz S-1000
Re: DWG File
Postby LittleGreyMan » Thu Oct 11, 2018 10:20 am
Did you try the "join open vectors" feature? Menu Edit> Join vectors or button with blue rounded rectangle with yellow nodes.
Unless you have important spaces between vectors, it should work fine. You may be able to select all vectors.
After that, don't forget to simplify your vectors with the "fit curves to selected vectors". Otherwise, you'll have zillions of nodes as curves are translated into very small sections in the dwg.
Best regards
Didier
W7 - Aspire 8.517
LittleGreyMan
Re: DWG File
Postby daibeer » Thu Oct 11, 2018 1:58 pm
Thanks for that, I will try that now. Cheers
Dave
daibeer
Return to Aspire - General
Users browsing this forum: Wayne Locke and 29 guests
