I need an Aspire job doing - create job for me to cut on VC
Re: I need an Aspire job doing - create job for me to cut on
Postby martin54 » Thu Oct 11, 2018 10:09 pm
Since you only have post a few times, I'm guessing you're new to VCP. In the 2D view, select all. You should be able to then re-size with the corner squares to get a 90mm dish.
Maybe not that new Mike, look at the date joined :lol: :lol: :lol:
Postby Nick.Lumb » Fri Oct 12, 2018 4:23 pm
Thank you so much Mike-S.
I have now cut the Acorn and Leaf and it looks good. More to the point, my customer likes it too! Can I give you something for your kindness?
I'm not sure what you mean by "top and bottom." If it's during import, select the "bottom" button to get a uniform blue color on the model (that moves the model down to be fully inside your block of wood). Darker blue areas indicate to model is being sliced and not completely inside the material. Then click OK.
I was importing using "cut both sides" hence the top and bottom jobs/surfaces created. This is my first 3D job in VCarve although I have done quite a lot of 2.5D work and lettering; this has continued my learning curve, so thank you to everyone who contributed to my further education :-)
Nick
Nick.Lumb
Model of CNC Machine: Very solid, home-made running MACH3
Postby Mike-S » Fri Oct 12, 2018 5:27 pm
Nick, glad you could please your customer--and that you learned some things.
Can you post the finished project?
Mike-S
Postby highpockets » Fri Oct 12, 2018 6:44 pm
Nice job Mike!!!
Previous
Return to Aspire - General
Users browsing this forum: mark-s, Tailmaker, vfauto and 32 guests
