Chair Back
Chair Back
Postby sheiney » Fri Oct 05, 2018 12:14 am
I'm trying to carve letters on a curved wooden chair back the length of the back is 10.5 inches the height is 2.0 inches and the depth of the curve is 0.5 inch. I tried to make a dish with aspire but the curve came out on the width instead of the length. Anyone have some ideas?
sheiney
Re: Chair Back
Postby spinningwood » Fri Oct 05, 2018 12:33 am
Draw a vector showing half of the curve you want (include a vertical on the outside that is the height of the curve) for the back. Use the turn and spin tool to create a dish. Draw a box around the area you want to carve and clear the model outside that box. Project your carving onto the model. If the curve you drew in the first step matches your material you are good to go, if it doesn't then probably not so good to go.
Ed
spinningwood
Model of CNC Machine: Taig Mill and Self Built Routers
Re: Chair Back
Postby highpockets » Fri Oct 05, 2018 1:00 am
Something like this?
You might also take a look at G-Code Ripper http://www.scorchworks.com/Gcoderipper/gcoderipper.html
Re: Chair Back
Postby spinningwood » Fri Oct 05, 2018 3:39 am
By the way, the process I summarized above will give you a slight curve on the short dimension. If that's a problem for you, then you can use a two rail sweep instead to avoid the curve in the short dimension.
Ed
spinningwood
Re: Chair Back
Postby sheiney » Sun Oct 07, 2018 8:21 pm
Highpockets
That's what I was thinking of regarding the look. I'm not sure how you did that would you explain in more detail please?
sheiney
Re: Chair Back
Postby highpockets » Sun Oct 07, 2018 11:00 pm
I used the two rail sweep modeling tool to create the curve.
I created a box 10.5x2 to cutout the chair back (I don't think this applies to your need)
Using V-Carve and checked Project toolpath onto 3D Model
Re: Chair Back
Postby sheiney » Tue Oct 09, 2018 11:14 pm
Thanks a lot highpockets
I was able to get the look and tool pathing set the way I wanted now to do a test piece and see how it turns out.
sheiney
Return to Aspire - General
Users browsing this forum: Google [Bot], vfauto and 34 guests
