I would like to be able to make some boxes from a single board and have the grain structure wrap around the box.
I'm far from an expert using Aspire & I'm not sure how to CAD the 45 degree per side (90 degree for two sides) per the attached sketch (not an artist either!).
Is there a video or a tutorial anyone could point me to?
Rick
Box From Board
- Model of CNC Machine: Avid CNC
Box From Board
- Box_From_Board.pdf
- (43.85 KiB) Downloaded 153 times
Re: Box From Board
I just realized the pdf is upside down......
Re: Box From Board
That's an easy project for a table saw, but if you would rather use the cnc, use a 90 degree v-bit and use "profile on" for the dividing lines.
Re: Box From Board
Here is an ancient thread that discusses the process: Making boxes
Re: Box From Board
With table-saw you don't even need to cut through the board at any time: http://lumberjocks.com/BritBoxmaker/blog/17048
Steven
Steven
