printing to exact size
I have a 3" x 8" rectangle to print to size as a template, Aspire prints but not to exact size?
Re: printing to exact size
so it appears from Zero responses there is No way to scale your drawings to print ?
- highpockets
Never tried it, but see if this helps...
viewtopic.php?f=3&t=29061
- Model of CNC Machine: Sieg, much modified.
Hi there,
Did this just the other day. Assuming you have Adobe Reader (free download). From within Aspire, choose File > Export... > PDF this gives you the PDF exporter pop up window,
> click the export button > Save (to your choice of folder). Now open Adobe reader, choose the file of the image to be printed >File > Print... > in the printer driver look at the page size & handling area of the window & choose "Actual size" > then hit the Print button.
Works for me every time. I hope this is of some help to users of the software as I have gotten so much help from other forum contributors over the years.
- rscrawford
- Model of CNC Machine: CAMaster Cobra 408 ATC, ShopSabre IS408
All else fails, mount a pen in your CNC and draw the template on a piece of paper taped to your table
Russell Crawford
The print function is not designed to print to scale. As has been said you need to use the PDF function to print to scale.
ok thanks maybe its something they can work on for future updates. if the software can cut accurate it should be able to print accurate.
I bet that if Vectric adds this feature, we'll see on this forum a lot of posts from users having issues with it simply because their printer settings are not correct or their printer is not homothetic which is a current issue. And support will probably have a lot of reports too.kevrgood wrote:if the software can cut accurate it should be able to print accurate.
Adding the pdf export is a wise decision. Vectric products are not intended to print and they provide an output for this.
Best regards
Didier
W7 - Aspire 8.517
Didier
W7 - Aspire 8.517
Seems as though a "plot" rather than a Print -to-scale feature would be easier to implement. Years ago many printers supported code that looked very similar to g-code. HPGL for one. In the DOS days I would write simple printer interpreters to take vector output from my simple CAD program and "plot" to whatever printers/plotters we had. What little I know of post processors suggests they are basically the same. Outputting directly to a connected printer from a post processor may be the biggest challenge.
4D
4D
