Aspire simple shape issue V9.508
graffix11
Model of CNC Machine: Two machines, CRP 48x96 and a xylotex
Post by graffix11 »
Trying to create a simple shape froom clean closed vectors and the shape is way outside of the lines on both sides. Not even symmetrical even though the vectors are. There are no nodes either in the area it goes off. Ill try to restart the software but...
graffix11
Re: Aspire simple shape issue V9.508
Post by graffix11 »
converted to bezier arcs and it worked fine...
garylmast
Post by garylmast »
Cut the ends off, do not have a closed vector. One of the ends that is not connected used as the cross rail.
graffix11
Post by graffix11 »
You need closed vectors to use the create shape tool. I was not attempting a sweep. I created the part already but vectric may want to take a look at this and fix something. The part made had a domed shape, limited to height to produce nice rounded edges. Thanks though...
garylmast
Post by garylmast »
Sorry, misunderstood what you were doing.
Mark_R
Vectric Staff
Model of CNC Machine: Shopbot
Post by Mark_R »
graffix11 wrote:I created the part already but vectric may want to take a look at this and fix something.
Please do send in the file to support if you can and we will take a look. I tried to recreate the problem from your screenshots but didn't get the same results. Thanks.
graffix11
Post by graffix11 »
Ok I managed to get it to do it again by switching it back to arcs.
graffix11
Post by graffix11 »
sent
Mark_R
Vectric Staff
Post by Mark_R »
A belated thank you for sending in the file. This issue should be fixed in 9.510.
Regards,
Mark.
